Glad I could help, djxtortion.
Oh Behringer and Atomix, when will you two get married and fix the issues? :P I still like the BCD2000 though, but it went from love to like. :) I use the microphone through my sound card as a workaround. No problem.
geposted Fri 16 Nov 07 @ 8:48 am
what do you do with that XML file? just have it on your computer, do i have to put it somewhere?
Thank you!
Thank you!
geposted Wed 16 Jan 08 @ 2:21 pm
Sorry to bring this old topic up, but I have the exact same problem, I want to be able to hear with the ASIO Driver selected as if I had mono separated selected. Is that possible in any way?
geposted Tue 11 Mar 08 @ 2:17 pm
Freehat, go to Config -> Keyboard shortcuts -> load and then load the file
The solution I found was instead of picking the ASIO Driver you pick Mono separated and then choose the BCD 3000 as your soundcard.
Maybe that helps :)
Maybe that helps :)
geposted Tue 11 Mar 08 @ 10:18 pm
Hi I`ve done everything as you write but now sound going only through headphones no speakers. i have BCD 3000 and VDJ 5. Is anyway that can be fixed? i`m trying to fix this all day long and nothing....
NOOO NEED HELP i`ve change for : two cards first primary secound bcd3000 and works perfect :))) maybe this help someone!!!
geposted Tue 27 Apr 10 @ 12:21 pm
Did it work for you?
geposted Fri 20 Aug 10 @ 3:05 pm
