I'm currently running Numark Cue/Virtual DJ off a MacBook Pro and I'm having a bit of trouble with setting up an external soundcard.
I own a Total Control Deck and a M-Audio Audiophile Firewire external card.
The card works absolutely flawlessly when I'm only using one audio output for it, as in if I select to only use one audio driver the card belts out sound perfectly
The problem comes when I try to use a setup like headphones & audio, and split the sound at all, (The entire reason I bought the box for cueing). I'm assuming this must be a software issue because the card works absolutely fine in all other circumstances.
However, when I do this, I get an awful distorted sound that somewhat resembles whats playing but is completely unusable. I was hoping for some assistance. Any help would be greatly appreciated.
If you need any more information about the setup feel free to ask.
geposted Mon 24 Sep 07 @ 6:06 pm
You should ask this in the mac forum as the mac user are always there n u will get more help:)
geposted Mon 24 Sep 07 @ 6:09 pm
Thanks, I wasn't exactly sure where I should post it :-)
geposted Mon 24 Sep 07 @ 6:13 pm
It ok. but dont double post it as it may cause confusion. just wait a while maybe one of the mod can move this thread there:)
geposted Mon 24 Sep 07 @ 6:14 pm
