I just bought a numark total control but it came with a BS 7 day trial of CUE
i have a cracked version of virtual DJ
is there any way i can use my total control on VDJ?
if so please tell me how , im so frustrated i spent 300 bux on nuthing
geposted Fri 28 Sep 07 @ 11:51 am
Well you spent 300 on the controller that's what you bought.
If you have VDJ - you need to register it. http://www.virtualdj.com/fusers/modifuser.html
geposted Fri 28 Sep 07 @ 1:11 pm
Pls uninstalled that crack n use the legit demo from this site.. u get 20 days to use with ur total control n if u like it do support the development by purchasing it. thnks
geposted Fri 28 Sep 07 @ 3:42 pm
try the other install disk you should have cue le on it and have a valid serial for it ,
which you can register in your profile :)
geposted Fri 28 Sep 07 @ 6:24 pm
