please help me if you know wath this mean...
can´t get my hercules to work right with the VDJ =/
thanks for all help I can get!!
//DjK
geposted Sat 29 Sep 07 @ 2:12 pm
this means that you have a wrong setting
try this
inputs : none
ouputs : headphones
Channels : 1/2 main 3/4 headphones
or if you are using vista
you must install as administrator
http://www.virtualdj.com/forums/71646/Hardware_Technical_Support/__Mk2_Home_Users_on_Vista_(please_read_if_you_have_direct_x_error).html
try this
inputs : none
ouputs : headphones
geposted Sat 29 Sep 07 @ 2:37 pm
Thanks, I dubbel post becuse I dind´t know about this "PC Version Technical Suppor forum"
back to the problem..
I have the settings you wrote but stil not working right =/
I can move the fader´s and al that but not press play or scratch.. the songs not starting, you see?
have the new vdj.. maybe go back to the old?
geposted Sat 29 Sep 07 @ 4:01 pm
Hi.. I have now undrestand that the problem is with the hercules mr2 because vdj work fine without it..
I can´t liten to any audio with the hercules as a sundcard... any idea´s ?
geposted Sat 29 Sep 07 @ 5:12 pm
have you got the latest driver from herc
what is your spec?
what is your spec?
geposted Sat 29 Sep 07 @ 9:42 pm
Try updating your Direct X, you can get it here:
http://www.softwarepatch.com/windows/directx.html
geposted Mon 01 Oct 07 @ 4:53 pm
Thanks for all help but I know wath the problem is now..
I have a webcam with integrated microphone. everythings work fine without it.. but can´t understand why I can´t have it intalled ?
any idea´s ?
any idea´s ?
geposted Fri 05 Oct 07 @ 1:59 pm
Just make sure that you haven't selected ASIO in the the DJ Console Control Panel and you should be fine.
geposted Fri 05 Oct 07 @ 4:05 pm
