I did a "*.mp3" search on the "My Music" folder and I get a total of 5942 files. I went to VirtualDJ and went to the folder and did a recurse on it (I have the "Search Database" set to "Add automatically"). I get 5942 files as well. That means that all the files are being read so I thought that all is well with my VirtualDJ database.
The problem happens when I go to change the database with the buttons in the "Browser" tab. I click on the "Check" button and now it says that 5919 files are in SearchDB with 23 saved old entries. I did not do any change to the "My Music" folder. I did not change the file paths of the MP3 files or delete them. Can anyone please explain why this is happening so that I can rectify the situation?
I thought to look at the XML (VirtualDJ 5.0.4 database file) to look at the "saved old entries" and found 23 weird entries at the bottom and one actually had a path name in English instead. Only one!?
Here is an example of how the old entry looks like (I had to add the returns (by pressing enter) in between the FilePath value in order to prevent the forum's display from getting stretched out):
I think it might be attributed to weird characters that are used for the file name for some of my MP3s. For example, "Tatu - 30 Минут - 200 По Встречной.mp3". Is this why?
FilePath="C:\\Documents and Settings\\(User Name)\\My Documents\\My Music\\DJ Siege Karramba feat. Tatu - Pocaluj.mp3" Flag="16">
<Song FilePath="|43003A005C0044006F00630075006D0065006E0074007300200061006E0064
002000530065007400740069006E00670073005C00570069006C0062006500720074002
00043006500640065006E006F005C004D007900200044006F00630075006D0065006E00
740073005C004D00790020004D0075007300690063005C00875B1A593075D230AB30EB
305C005700610069007400200061006E00640020005300650065005C00480069006B006
1007200750020002D00200046006C00790020004D006500200054006F00200054006800
650020004D006F006F006E0020002D0020005700610069007400200041006E006400200
053006500650020002D002000300033002E006D0070003300" Flag="16">
<Display Color="4013769" Tag="2" />
<Infos FirstSeen="710081323" />
</Song>
geposted Mon 08 Oct 07 @ 7:36 pm
Hum, think you might be right about that.
5.1 has improvements on language on the list of to-do's, so I think this is releated to that maybe
geposted Mon 08 Oct 07 @ 9:39 pm
Thanks, as long as it is fixed eventually. It is not too bad of a bug for now, only that I cannot find those 23 tracks if I had to search for it at an event.
geposted Mon 08 Oct 07 @ 9:42 pm
Well, you could remove the Russian characters in Tatu and the other 23 tracks, until the characters are supported :)
geposted Mon 08 Oct 07 @ 10:31 pm
Yeah, the hard part is finding the tracks that have the unsupported characters. The Tatu ones are easy to find since the word "Tatu" is in English, but that is only 18 of the 23 files and I do not know what the other files are named. Is there a way to search for weird characters? Haha. :-)
geposted Tue 09 Oct 07 @ 6:49 pm
Here is a little more proof that the language might be the problem, but only 7 files and not 23 are found here. These are the files that were not able to be scanned when I ran a BPM check for my entire database. The "Impossible to open the file !!" is the error in the "File Infos" window. I wonder about the other files that did not show up here, but were successfully analyzed.
geposted Wed 10 Oct 07 @ 9:35 pm
