Hi guys, have a Dac-2 controller and currently running VDJ 5.
Although the controller seems to run the basics when I go into the VDJ config menu for controllers the Dac 2 option is showing a red dot rather than green indicating that it is not properly configured.
I do not seem to be able to search for files from the controller but like I say can do the basics the same as I would be able to do using a CD controller. Cant help feeling that thangs are not as they should be if the software is not showing the controller as properly confibured.
Also the Dac 2 section on the config menu is at the same place as the Numark DMC...
How can I get my red dot to go green
geposted Wed 10 Oct 07 @ 3:42 pm
As a registered licensed user you would have access to a couple of custom mappers for the DAC-2. Along with other great tools.
If you have a license please register here - http://www.virtualdj.com/fusers/modifuser.html
If you do not have a license, please purchase one here - http://www.virtualdj.com/purchase/
geposted Wed 10 Oct 07 @ 5:24 pm
