DEAR ALL USER
i try to set up the driver for the dj console mp3 mac edition "HDJMP3_Tiger_3_2" but vdj don't recognise it and ni application/hercules i have two folder one for the mk2 (wich work well and have all the folder) and the auther call mp3 wich only have one folder "misc" , i bet we maybe shall have same folder with control panel just as the mk2 ??
i can't understand the set up seems to work well (i try it twice)
thanks for your help
geposted Thu 11 Oct 07 @ 12:16 am
i dont belive you can have a mp3 console and a mk2 installed if thats what you are trying to do ?
geposted Thu 11 Oct 07 @ 11:27 am
i bought both ok i'm bit crazy with this products but no i don't want to use them both in same time.
in fact my djconsole (mac edition) work well with traktor but virtual dj don't recognize it it always give me a red light in the config
i want to put my mk2 back on my pc and my dj console on my mac
geposted Thu 11 Oct 07 @ 10:33 pm
ok try reinstalling the herc driver please
and see if you can map the mk1 manualy by going to > options > remotes > midi > options
geposted Thu 11 Oct 07 @ 11:03 pm
thanks for your patience and infos
each time i try to config the midi vdj crash
maybe shall i reinstall it all ??
vdj and herc driver
vdj and herc driver
geposted Thu 11 Oct 07 @ 11:08 pm
i would recomend you try deleting the perference file
yourcomputer/users/youname/libary/preferences
its called com.atomixproductions.virtualdj.plist
then rerun vdj it can get rid of bad settings
v5 with many improvements isnt far off at all so hold on there :)
geposted Thu 11 Oct 07 @ 11:31 pm
