Hello,
I'm new to AtomixMP3 and I'm wondering if here's a way to set the initial level of the two gain controls? I've not found that in the docs so far, but I've read the part on what the gain controls do.
The reason is the initial gain is too high and is overloading (clipping). A lower setting would help with that.
Any suggestions welcome!
Thanks
Skip
Thanks
Skip
geposted Wed 17 Oct 07 @ 12:28 am
in options set gain to always zero bd
you should check out the much beter virtual dj
http://www.virtualdj.com
geposted Wed 17 Oct 07 @ 12:39 am
I don't see a place in options to set this. I'm using AtomixMP3 Version 2.3
Is it in a file somewhere?
Thanks,
Skip
Thanks,
Skip
geposted Thu 18 Oct 07 @ 7:08 pm
There is no that option, you have Always Match option which should be ok, but it might make problems if your tracks are not analyzed properly in AtomixMp3.
And please enter serial in your profile ;)
geposted Mon 22 Oct 07 @ 11:21 pm
I would love to enter the serial number, but it won't allow me to do so as it was purchased by my church under another email address.
Oh well.
Oh well.
geposted Thu 25 Oct 07 @ 6:29 am
just use their email adress in your profile then use the serial or make a profile for them then you get adons
geposted Thu 25 Oct 07 @ 10:13 am
Maybe this is better?
geposted Fri 26 Oct 07 @ 12:43 am
horray now you can claim your atomix goodies :)
geposted Fri 26 Oct 07 @ 9:35 am
