Is there any mapper for the BCD 3000 I can't find the way o make it work witn my mac book pro, i'm using VDJ version 4.3
regards
regards
geposted Thu 18 Oct 07 @ 4:11 pm
just download the 3000 midi map for v5 it will be fine in 4.3 for now
and be sure to install the bcd mac drivers ,
geposted Thu 18 Oct 07 @ 4:29 pm
I already did but doesn't work properly You can't make any changes on the default setings
regards
regards
geposted Thu 18 Oct 07 @ 10:00 pm
I forgot, in the manuals said that you don't need any drivers for Mac, I couldn't even find the drivers on the CD that came with the BCD 3000, Do I realy need a driver???
geposted Thu 18 Oct 07 @ 10:17 pm
i will check maybe its the 2000 thats needs them
geposted Thu 18 Oct 07 @ 11:21 pm
I have both bcd2000 and 3000 either one can't work with VDJ
geposted Thu 18 Oct 07 @ 11:44 pm
Hi im in this forum, i bougt a new macbook pro this saturday and i wait for arriving, mi cousin have a vdj with a mapper v2 or something like that in xp for bcd 2000
this work on mac at the same function?
geposted Mon 22 Oct 07 @ 5:31 pm
no if you want acess to the mac version and its benifits you need to purchase ;)
hope to see you with us soon
geposted Mon 22 Oct 07 @ 5:53 pm
Yes i ask because i planning to buy but i don't know what version is the best for me in mi new mackbook pro, what you recommend?
tankss
tankss
geposted Mon 22 Oct 07 @ 6:57 pm
get virtual dj pro :)
http://www.virtualdj.com/purchase/
geposted Mon 22 Oct 07 @ 7:04 pm
tanks i buy now
;-) now i in the VDJ Familiy yayyyyy
geposted Mon 22 Oct 07 @ 7:23 pm
now yes tanks
geposted Mon 22 Oct 07 @ 7:52 pm
welcome now grab your mac version :)
http://www.virtualdj.com/update.html
geposted Mon 22 Oct 07 @ 8:05 pm
my flatmate has a mac with a bcd3000 and virtual dj pro.
none of the lights work. is this normal for the mapper?
geposted Tue 23 Oct 07 @ 10:41 pm
credit to you havent heard that one yet !
if you like this program please purchase it
geposted Tue 23 Oct 07 @ 10:48 pm
which lights are you refering to?
there is greater support for newer controlers in the upcomming V5 update for registered users
hope to see you with us soon :)
geposted Tue 23 Oct 07 @ 10:49 pm
lights on the cue buttons, kill buttons, etc. the only light that is on is the power button.
geposted Wed 24 Oct 07 @ 2:19 am
