Topic: is it possible to change skin format ??
ivarPRO InfinityMember since 2004
i wanted to know if i can change a skin from 1024 by 768
to 800 by 600
if this is possible how can i do this ???
thanx a lot
geposted Tue 02 Nov 04 @ 6:10 pm
mp3jrickPRO InfinityHonorary MemberMember since 2003
DL a 800x600 skin and install it.
Works for me here.
geposted Tue 02 Nov 04 @ 6:22 pm
yeah but i prefer to work with a certain skin wich sometimes i have to use in 800 by 600
geposted Tue 02 Nov 04 @ 6:25 pm
What skin do you like using Ivar?
I thought most of them came in 2 sizes.
geposted Tue 02 Nov 04 @ 7:22 pm
i always use the Pioneer CDJ700S
i tried to change it xml folder myself but i don't find it very easy
geposted Wed 03 Nov 04 @ 10:01 am
djzeroPRO InfinityMember since 2003
goto http://www.atomixfr.com/converter/
and select the current resolution and then the new resolution, and it will create a new XML file for you. all you need to do is change the size of the BPM file..
enjoy
geposted Wed 03 Nov 04 @ 10:24 am
thanx a lot man, i will try is straight away
geposted Wed 03 Nov 04 @ 10:26 am
it gives me an error in the XML file
i converted it but what do i do next
do i create a new folder where i copy both the new XML + the bpm file (and what is the best way to convert the bpm file)
what is the best way to do it all ?
thanx a lot
geposted Wed 03 Nov 04 @ 12:31 pm
found it
i forgot to give the files the same name
and now it works perfect
thanx a lot
geposted Wed 03 Nov 04 @ 7:13 pm
