Do i need a new mapper to use the bcd 2000 and vdj 5?
geposted Fri 19 Oct 07 @ 3:56 pm
nope, the only thing you need is to select bcd2000 in the control remote section on configutaions window and if you want to work better go to dowload section and get the moramax's bcd2000 mapper it works great!!!!
regards
Dj Quintana
regards
Dj Quintana
geposted Fri 19 Oct 07 @ 4:44 pm
Get the BCD2000 version 3 Mapper, without it, you will not be able to release your beatlock to mix with half and quarter notes, and your Sync buttons with the Hardware will not work properly. Its best to try the Mapper. Download it at the External Tools section.
geposted Sun 21 Oct 07 @ 6:38 pm
