Forum: VirtualDJ Plugins
Topic: BCD3000 / 2000 mapper: new version available - Page: 1
the new BCD2000 mapper 3.0 update is available:
http://www.virtualdj.com/addons/view.html?type=tool
v 3.0
-added sampler mode
-changed key for samples and effects to respect default skin sequence
-updated automix function to be compatible with virtualdj 5.0 rev.4
-pitch function now is better
-added “hot cue 1, 2, 3”
-added “jogs disabled” feature
and others(see the manual for more details)
Attention: it's compatible starting from Virtual 5.0 rev4
geposted Sun 21 Oct 07 @ 3:44 am
Super Max & thx for this update & congratulation for your work....
Great vdj day a V5R05 release with search fix & and new bcd 2k mapper!!!
As vfdj told in the french forum, Berhinger should give you royalties for your mapper ;-)
Hello I test the new 'Mapper v3' and my usage is perfect because I use my BCD 2000 and Trigger Finger, I have it set to trigger the midi mapper done my way and bcd2000 with the mapper. My question is, is there anyone working on this mapper for mac?
thanks to you for the collaboration...now i'm working for a new update to implement te analog phono/line input.
bye:)
Hey Moramax this is good job....
great as always moramax:)
the skip beat function would also be great :-)
nice tool !! great work
just seen the new plug in 3.2. Will have a mess with it tommorrow
Hi,
is it possible to toggle this tool on and off while mixing ?
WoW Moramax, this is really good work.
One point of what i think is very interesting:
Didn't anybody say the analog-in of the BCD2K is not usable by VDJ because of the so called "crappy" hardware?
And now you come and do this by just a (sorry for that) little piece of Software?
Is this is possible with the analog-in, there might be a chance to do the same for the mic in?!
Again, thanks for your good work
Tanzi
New 3.3 Versions are available for 2K & 3K consoles.
Thanks to his outstanding job, Moramax fixed the Tempo Pitch problem caused by new vdj 5.0.6 pitch ranges.
Всем привет ребяты! жаль что вы все мыслите на импортном языке, хороший сайт,много чего интересного, но одна мне непонятная фишка - ничего нужного несольёшь пока недостигнешь определённого уровня пользователя. У меня BCD2000 , я пользуюсь разным софтом и немогу конкретно на какомто остановится, вот допустим в TRAKTOR3 неработает SCRATCH, а востальных неустраивают скины.
вот я и решил обратится с мольбой на офицальный сайт VirtualDJ. HELP pleas)
[moderator] Translation:
All greetings guys! sorry that you all think on the import version, a good site, which a lot of interesting things, but to me an inexplicable chip-anything you want nesolesh nedostignesh until a certain level of user. I BCD2000, I take different firmware and cannot kakomto specifically to stop, this is acceptable TRAKTOR3 Closed SCRATCH, and vostalnyh neustraivayut skins.
here I am, and decided to ask the cries for official site VirtualDJ. HELP pleas)
professional dj you ask questıons
thank you cioce! ;)
Dear Moramax...
Thank you for your plugin! Thanks to you I will buy PRO version of VDJ.
Plugin has everything...but I wonder: did you impemented SHIFT function (for example working with jogs and other button)?
yes, i confirm
some keys has double funcrion by press two keys at same time
Thanks.
Do you know is it possible to implement prelistening of master out? Or in VDJ there is no such option?...
65%
