I have set up 2 time coded vinyls to my numark tt and I am using a numark 1002 mk mixer with a hercules mkII soundcard.
I am getting a distorted sound when I crossfade quickly from one tt to the other?
geposted Sun 21 Oct 07 @ 7:35 am
i would suggest you try using the console with the asio for all driver instead of the mk2 ones
http://www.virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2.html
the hercules drivers are slow and unresponsive
i would aslo suggest you set auto latency and lower your performance tab a bit on performance options
geposted Sun 21 Oct 07 @ 12:55 pm
