Hello
I have a mac and i am jut getting started with digital DJing.
Cue LE came with a product that i purchased but i want the full version...
I am using the Numark total control
What are the benefits or drawbacks to buying VDJ over CUE or vice versa?
I used the VDJ demo and like it and i also like the look of cue
Please let me know if there is a comparison somewhere or any advice before i spend the$$
thanks
C
thanks
C
geposted Wed 24 Oct 07 @ 10:05 pm
same program different name :) for different distrubution channels
*moved to mac forum*
geposted Wed 24 Oct 07 @ 10:06 pm
<---- I have a license for both (well Virtual Vinyl) and also use a Mac. They are essentially the same software. Cue's skins for some reason fit better on my Macbook Pro 17" but VDJ's updates come out before Numark's. I believe you have to change the xml code to get skins to properly working with Cue. I did. Go with VDJ, that way you won't have problems with skins.
geposted Wed 24 Oct 07 @ 10:11 pm
can you use the cue skin on vdj?
geposted Wed 24 Oct 07 @ 11:12 pm
yes as a pro user you can download it for vdj
its the same as the vdj skin with a cue logo added
geposted Wed 24 Oct 07 @ 11:45 pm
