Is it better to use a numark usb mixer with two icdx on a mac than to used a mk2 with two icdx on mac or any other suggestion that i can use because the mac with the mk2 and the 2 icdx doesnt work like how it work on the pc and i want to use a mac as it is more stable with music give a suggestion i need asap. thanks in advanced
geposted Thu 25 Oct 07 @ 12:38 pm
what do you wish to achive
play cds through vdj or utilise the midi control?
geposted Thu 25 Oct 07 @ 12:40 pm
geposted Thu 25 Oct 07 @ 12:49 pm
well as you already have the mk2
i would use this for headphone monitoring and main output and crossfading
then use the icdx as jog/stratch controlers
geposted Thu 25 Oct 07 @ 1:16 pm
i have a dxm06 from numark and two icdx an mk2 pc version which work great on a pc an allow other user to used cd when they want but when using the mac with same setup as the pc im not getting the same thing thats y i ask if the the usb mixer from numark will be my solution to both system
geposted Thu 25 Oct 07 @ 1:31 pm
for mk2 + icx
choose on sound
inputs : none
outputs : headphones
card: 4.1
Driver : mk2
channels 1/2 main 3/4 headphones
And enable Mk2 and Icx in mid
Options > remotes
choose on sound
inputs : none
card: 4.1
Driver : mk2
Options > remotes
geposted Thu 25 Oct 07 @ 1:32 pm
will this setting all me to switch to cd when using the icdx
geposted Thu 25 Oct 07 @ 1:50 pm
currently in 4.3 mac
it isnt possible , but in v5 comming soon bypass mode mixing real CD , with virtual dj
will be included ,
will be included ,
geposted Thu 25 Oct 07 @ 2:04 pm
ok thanks skyfxl then i will have to use my pc for the rest of the time until v5 comes for the mac
geposted Thu 25 Oct 07 @ 2:16 pm
