upgraded to latest revision. Prior was using the DAC3 v.4.3 Skin with no issues. With latest revision when I try to change skins, getting: Invalid skin; error in line 0 of xml. Happening with anything other than default skin....
geposted Fri 26 Oct 07 @ 8:54 pm
My resolution is at 1280x1024. i downloaded the V - Mix 5.2 Multi Instance 1280 x 1024.zip...It doesn't work
The Mix Lite V1.0 1024 x 768.zip does work
The - DAC3 V4.3 1280x800.zip doesn't work. It did work with 5.0 rev 4
I thought it might have been this line in the skins not working: <?xml version="1.0" encoding="UTF-8"?>
This line though is in the Mix Lite Skin that does work
I', stuck !
Help!
I', stuck !
Help!
geposted Sat 27 Oct 07 @ 2:51 am
