Hi
I bought Mixxman DM2 USB PC decks last week end and had problems instaiing them, i've found several sits that suggest using DM2 to MIDI but i don't understand how it works and also read the tutorial here ( http://dm2.proboards23.com/index.cgi?board=genaudio&action=display&thread=1189102233 ) Which i don't understand one bit.
I was wondering if someone could help me out a little bit.
Also, i was thinking of getting a HERCULES. Either a:
HERCULES DJ Control Mp3
or a
Hercules DJ Console Mk2
Which one would be compatable for VDJ?
Which one would work with Audgy Sound Blaster 24Bit Sound Card?
And which one would be the better one (EG, Easie to use.)
I'm a n00b Dj as such. I just like messing around now and then.
P.S. I believe that the DJ Console Mk2 has a jack for head phones which would be a great advantage, would the Control Mp3 also have this feature?
Many thanks
And i hope that you guys can help me with a few of my questions above.
Regards
Dan
or a
Many thanks
Regards
Dan
geposted Sat 27 Oct 07 @ 8:41 pm
both are compatable and include their own copy of console edition vdj
http://www.virtualdj.com/products/djcedition.html
however the mk2 has its own soundcard with headphone support
the mp3 console is just the contoler on its own and is based on V1 console which has weaker buttons than the mk2
i would recomend you get the mk2
you can aslo get a discount if you buy one of the consoles should you choose to
upgrade
i have aslo created a system to utilise the midi tools for the dm2 for pro users
http://www.virtualdj.com/addons/view.html?type=tool&page=2
but i must warn you that the dm2 is designed as a toy and not for serious use and such has low performance
upgrade
geposted Sat 27 Oct 07 @ 9:00 pm
I don't quite get the last bit about the weaker buttons.
Anyway, thanks for the reply. I just want one thats used for just messing around. Quite a lot of buttons for Sound FX etc
The sound card that comes with the MK2, would it be a 5.1 sound card and woud it be PCI?
And as for the Midi tool, i'm affraid to say that i've purchased a illegal copy from eBay without knowing it. eBay have been informed and so have Atomix. So i can't download the tool (Which serves me right for buying software from eBay)
is there anyonter way i can get my DM2 to work?
Thanks
Dan
Thanks
Dan
geposted Sat 27 Oct 07 @ 9:17 pm
I've also came across this.. https://www.virtualdj.com/shop/checkout.html?discount=djc2
As i've mentioned, my softwear is unfortantly illegal. So if i buy a pair of consols and enter in the serial number what sort of discount am i looking at?
Thanks
Dan
Thanks
Dan
geposted Sat 27 Oct 07 @ 9:26 pm
the buttons on the mp3 console tend to stick easily
the mk2 is a usb 5.1 soundcard
no you would need to buy pro
you are allowed to use one discount
Thanks for the reply
**the mk2 is a usb 5.1 soundcard**
I thought it connects via USB? Just like my DM2?
***no you would need to buy pro
you are allowed to use one discount***
Well when i buy one of these consouls and i enter the serial number to buy a licenced version of VDJ Pro, how much discount would i get because i entered in one of these serialnumbers (Obv 1 serial code per user)
Thanks
Dan
PS. Sorry for sounding n00bish, but i want to make sure of everything before i purchase anything.
Thanks
Dan
geposted Sat 27 Oct 07 @ 9:32 pm
I also notice that on Hercules website they say the dimension of the 2 decks are: 235x200x65mm
Is this the overall size (If so its very small) or the distance between the 2 decks?
I'm comparing the 2 pictures and i can't find any difference but at the end of the day your paying for the extras like sound card etc.
geposted Sat 27 Oct 07 @ 9:45 pm
it is a usb device yes
you can use one console at a time with your computer
unless you need two just get the one
or get two mk2s
the console is quite compact yes its designed for mobile users if you need somthing larger
look at the xponent or VCi100 with virtual dj pro :)
as to the dm2 dont base your decisions on purchasing on this as it wont be nearly as good as the mk2 or mp3 console
€40 discount for DJConsole MK2 / DJControl MP3 customers
Virtual DJ is available for you for only €199 (plus VAT) or $249.
or get two mk2s
geposted Sat 27 Oct 07 @ 9:52 pm
Sorry to bother you again, but what do you mean by this.
**you can use one console at a time with your computer
or get two mk2s **
Dosn't the MK2 have 2 'decks'??
Anyidea where i can get the xponent or VCi100 for a reasonable price?
Thanks
Dan
or get two mk2s **
Thanks
Dan
geposted Sun 28 Oct 07 @ 12:24 pm
you mentioned you wanted to buy two consoles
you can only use one mk2 console with your computer at one time
an mk2 has two jogs yes
where do you live?
where do you live?
geposted Sun 28 Oct 07 @ 1:30 pm
Yer.. I just want to get 1 consol. And yes i see they have 2 jogs.
I live in Bedford, United Kingdom
geposted Sun 28 Oct 07 @ 6:05 pm
the cheapest for VCi and Xponent and aslo the fastest delivery ,
http://www.dv247.com/
as to the mk2
http://www.nusystems.co.uk/
as to the mk2
geposted Sun 28 Oct 07 @ 7:18 pm
HI
I bought a Hurcles Control MP3 (Not MK2) for £60 (used only a few times from eBay). I'll see how this goes.
i was wondering, if i wanted to 'scratch' (I know the controler isn't the best for scratching) What sort of music would i need (Accapella?) or is there a special 'Scratching CD's' you can buy?
Thanks
Dan
Thanks
Dan
geposted Tue 30 Oct 07 @ 10:40 pm
NO dun buy from ebay...cos normally the user have already registered the djc edition that should come with the console.. n licensed not transferable.. n i dun koe if the home edition of vdj that u have will let u use that as controller.. Did the console came with the software?? if yes.. try register it at ur profile n make that herc icon appeared:).. if it already been registered sorry u can't have the updates n i guess u have to go back to the seller for refund..
The only way to bypass this is U buy the pro version..so that u can use that console.
geposted Tue 30 Oct 07 @ 10:45 pm
Correcting myself. I see u have the djmixstation3 from Ejay n that wont werk..sorry..
So how is it, have u registed ur djc edition ??? With that u can have the upgrade to pro:)
geposted Tue 30 Oct 07 @ 11:08 pm
micky_mouse007 wrote :
HI
Thanks
Dan
Thanks
Dan
it is unfortunate that you purchased it seccond hand as you dont get acess to the newer 3.4 version
there is limited to no support for the hercules in mixstation / home edition
i must aslo draw your attention to this warning
http://www.virtualdj.com/products/djmixstation.html
geposted Wed 31 Oct 07 @ 9:52 am
Right. Arrived today and was in mint condition, with software and not a scracth on the deck. I noticed that the cross fader was easer to move across and didn't have any resistance. Where as the volume leverls have some resistance when you move them.
Is this part of Hurcles design or 'Damaged Item'?
Thanks
Dan
Thanks
Dan
geposted Thu 01 Nov 07 @ 6:38 pm
it is quite easy to move
add your serial to your profile and grab 3.4.1 :)
geposted Thu 01 Nov 07 @ 10:36 pm
