Hi,
I connected my mixer to my soundcard the 4.1 way.
But the crossfader sucks when using the 'front-speaker'-channel.
I can still switch between the 2 decks on 1 channel with the fader :(
Is there a way to fix this??
Thx and greetz,
kacper
Thx and greetz,
kacper
geposted Fri 05 Nov 04 @ 6:51 pm
so the problem is i hear on channel 1 2 decks instead of 1.
I can correct this with the crossfader but when i do this i hear nothing on channel 2 offcourse.
thx.
thx.
geposted Fri 05 Nov 04 @ 6:54 pm
You can not have 2 seperate outputs with the trial version.
This option is only available in the full version.
It could be that you are using a "dirty" version of VDJ. If that's the case, in order for you to get it to do what you want it to do, you'll need to completely uninstall your bad version, and then purchase and re-install the full legal version.
geposted Fri 05 Nov 04 @ 8:02 pm
I also had the same problem with a 4.1 soundcard. The solution is to get a new sound card, preferebly an external sound card. That will fix your problem..
geposted Sat 06 Nov 04 @ 9:22 am
