no working with numark 950 usb , does not reconise 2 outputs as pc version does.
so you can no use externar mixer usb as 2 separated sound cars and make prelisten in to mixer
it is the same promblem than mac version 4.3.
thanks
thanks
geposted Thu 01 Nov 07 @ 7:13 pm
try to using Mac's audio aggregate devices.
(Applications/Utilites/Audio MIDI Setup, create a new aggregate device and add both outputs from the mixer)
geposted Thu 01 Nov 07 @ 9:31 pm
HI . thanks for helping , but i dont know how to make work,
do you know where i can get mor informaton about setting up everything for the mac??? i mean how to set up in the mac x and then what configuration shall i set up in virtual dj.
i tryed yerterday but the sound was not right , i would be very please if you can help me out a bit more
thanks very much
thanks very much
geposted Fri 02 Nov 07 @ 10:41 am
niko you can learn a bit more here
http://www.virtualdj.com/forums/76062/MAC_Version_Technical_Support/Virtual_DJ___Cue_Manual_For_MAC_(4_3__5_0_BETA).html
i will aslo publish information on configuring devices
geposted Fri 02 Nov 07 @ 11:17 am
thnks man i got it working
geposted Fri 02 Nov 07 @ 8:40 pm
