I tried the beta today with my u46dj, but I can´t get any timecode input signal. I tested the inputs of the u46dj in other apps and all four input channes work there, but as I said not in vdj5. I can only choose the 4-in/4-out option, and only a 2chanel mixer with that soundcard. If I choose three chanel mixer I can only choose the numark interface.
BTW The output works fine on both chanels... and I have v2.2.2. of the u46dj control panel.
Any insight to this? Is it supposed to work at all?
geposted Thu 01 Nov 07 @ 9:28 pm
Try to create an aggregate device in the Apple's audio config window
(Applications/Utilities/Audio MIDI Setup, create a new aggregate device and add all the inputs and outputs from the U46DJ).
Then use this aggregate device as the driver in virtualdj.
geposted Thu 01 Nov 07 @ 9:35 pm
Ok. Tried that, and the input signal is now detected, but VDJ shuts down after a few seconds.
geposted Thu 01 Nov 07 @ 9:39 pm
That is, it shuts down if I try to use Auto-Config. I can´t however get a 100 signal when I try to set the signal manually. BTW what is the TC-up sliders for?
geposted Thu 01 Nov 07 @ 9:56 pm
VDJ 5 seems to be unstable on this
i tried to create this but it doesnt appear in the vdj list
when i tried to edit the default one , it aslo dissapeared
geposted Thu 01 Nov 07 @ 10:07 pm
Mine appears just fine, but the timecode signal is not read right, music is playing at half speed, and I can not autoconfig.
BTW, here is my latest crash-report.
Command: virtualdj
Path: /Applications/virtualdj.app/Contents/MacOS/virtualdj
Parent: WindowServer [84]
Version: ??? (1.0)
PID: 419
Thread: 0
Exception: EXC_BAD_ACCESS (0x0001)
Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x162a3460
Thread 0 Crashed:
0 ...atomixproductions.virtualdj 0x00096a76 0x1000 + 612982
1 ...atomixproductions.virtualdj 0x0009b364 0x1000 + 631652
2 com.apple.Foundation 0x9263e36a __NSFireTimer + 199
3 com.apple.CoreFoundation 0x9082a822 CFRunLoopRunSpecific + 3341
4 com.apple.CoreFoundation 0x90829b0e CFRunLoopRunInMode + 61
5 com.apple.HIToolbox 0x92dd9bef RunCurrentEventLoopInMode + 285
6 com.apple.HIToolbox 0x92dd9234 ReceiveNextEventCommon + 184
7 com.apple.HIToolbox 0x92e21c8f _AcquireNextEvent + 58
8 com.apple.HIToolbox 0x92fe445f _RunAppModalLoop + 105
9 com.apple.HIToolbox 0x92fe461c RunAppModalLoopForWindow + 96
10 com.apple.AppKit 0x933290b6 -[NSApplication _realDoModalLoop:peek:] + 153
11 com.apple.AppKit 0x93327fab -[NSApplication runModalForWindow:] + 171
12 ...atomixproductions.virtualdj 0x00098b18 0x1000 + 621336
13 com.apple.Foundation 0x925ef670 -[NSSet makeObjectsPerformSelector:] + 164
14 com.apple.AppKit 0x93255686 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1015
15 com.apple.AppKit 0x9324c98d loadNib + 260
16 com.apple.AppKit 0x9324c3b9 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 918
17 com.apple.AppKit 0x9324c01a +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 164
18 com.apple.AppKit 0x9324bf5c +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 392
19 ...atomixproductions.virtualdj 0x00026431 0x1000 + 152625
20 com.apple.AppKit 0x9334bd88 -[NSApplication sendAction:to:from:] + 107
21 com.apple.AppKit 0x9334bce1 -[NSControl sendAction:to:] + 101
22 com.apple.AppKit 0x9334de91 -[NSCell _sendActionFrom:] + 168
23 com.apple.AppKit 0x93360671 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1271
24 com.apple.AppKit 0x9337e25d -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 848
25 com.apple.AppKit 0x9337db0d -[NSControl mouseDown:] + 757
26 com.apple.AppKit 0x9333b3af -[NSWindow sendEvent:] + 5279
27 com.apple.AppKit 0x93555c94 carbonAppWindowMouseHandler + 244
28 com.apple.HIToolbox 0x92dd886b DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1093
29 com.apple.HIToolbox 0x92dd7f10 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 304
30 com.apple.HIToolbox 0x92ddf1f0 SendEventToEventTarget + 56
31 com.apple.HIToolbox 0x92ddf683 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1169
32 com.apple.HIToolbox 0x92dd8c22 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2044
33 com.apple.HIToolbox 0x92dd7f10 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 304
34 com.apple.HIToolbox 0x92ddf1f0 SendEventToEventTarget + 56
35 com.apple.HIToolbox 0x92e230c7 ToolboxEventDispatcher + 81
36 com.apple.HIToolbox 0x92e21adf RunApplicationEventLoop + 165
37 ...atomixproductions.virtualdj 0x000a59e8 0x1000 + 674280
38 ...atomixproductions.virtualdj 0x00002c42 0x1000 + 7234
39 ...atomixproductions.virtualdj 0x00002b69 0x1000 + 7017
Thread 1:
0 libSystem.B.dylib 0x9003f23f syscall_thread_switch + 7
1 com.apple.AppKit 0x9333566e -[NSUIHeartBeat _heartBeatThread:] + 1399
2 com.apple.Foundation 0x925f736c forkThreadForFunction + 123
3 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 2:
0 libSystem.B.dylib 0x90048a47 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90cde0ab TSWaitOnSemaphoreCommon + 163
2 ...ickTimeComponents.component 0x97dc5992 ReadSchedulerThreadEntryPoint + 4895
Thread 3:
1 ...ple.CoreServices.CarbonCore 0x90d19a70 MPWaitForEvent + 221
2 ...atomixproductions.virtualdj 0x00095661 0x1000 + 607841
3 ...atomixproductions.virtualdj 0x000956ab 0x1000 + 607915
4 ...ple.CoreServices.CarbonCore 0x90cb4f84 PrivateMPEntryPoint + 51
5 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 4:
0 libSystem.B.dylib 0x90009857 mach_msg_trap + 7
1 com.apple.CoreFoundation 0x9082a2f3 CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x90829b0e CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x9146441e HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x91464239 CAPThread::Entry(CAPThread*) + 93
Thread 5:
Thread 6:
1 com.apple.audio.CoreAudio 0x9147165c CAGuard::WaitFor(unsigned long long) + 212
2 com.apple.audio.CoreAudio 0x9147157e CAGuard::WaitUntil(unsigned long long) + 66
3 com.apple.audio.CoreAudio 0x9146fefa HP_IOThread::WorkLoop() + 690
4 com.apple.audio.CoreAudio 0x9146fc43 HP_IOThread::ThreadEntry(HP_IOThread*) + 17
5 com.apple.audio.CoreAudio 0x91464239 CAPThread::Entry(CAPThread*) + 93
6 libSystem.B.dylib 0x90023d87 _pthread_body + 84
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x162a3464 ebx: 0x00000041 ecx: 0xfffff85a edx: 0x00000000
edi: 0x00000041 esi: 0xfffff819 ebp: 0xbfffe2f8 esp: 0xbfffe290
ss: 0x0000001f efl: 0x00010293 eip: 0x00096a76 cs: 0x00000017
Command: virtualdj
Version: ??? (1.0)
PID: 419
Thread: 0
Thread 0 Crashed:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
geposted Thu 01 Nov 07 @ 10:12 pm
sjursjur, i posted ur crash report at the public beta thread.. Hope u will use that thread to report in future, if not it be messy as there be others with different problems posting a new thread. It is so it be easier for the dev team to look at it n we will discuss there. Thanks:)
geposted Thu 01 Nov 07 @ 11:03 pm
good idea!
geposted Thu 01 Nov 07 @ 11:23 pm
