Hi i decided to try the new version 5 of VDJ but were does my database go? as i can not afford to wait for to scan all my files again as i have thousands
please help
cheers
please help
cheers
geposted Sat 03 Nov 07 @ 3:14 pm
My documents/Virtual DJ/ Virtual DJ Database (owner).
geposted Sat 03 Nov 07 @ 4:05 pm
Hi it didnt work
plus the folder with skins has gone i added a new one and it wont read my skins
am stuck with the default skin wich is no good as it dont have a stop for a start
so why is ths version called an upgrade when the last versions are more popular still?
makes no sence to me
oh well support on here is as bad as Nato so am gonna uninstall it
saves me time
saves me time
geposted Sat 03 Nov 07 @ 4:42 pm
You make 1 post and within 1hr 30min you decide support is bad... Obviously not reading any other posts as there are SEVERAL threads about upgrading to version 5.
So, in the manual the first page after all the introductions to the software (page 6) is a page that outlines where everything has shifted to better support the Vista environment. Now all supporting folders/files are located in the My Documents -> VirtualDJ folder (oh, to include the manual) and the Program Files folder only stores the program executable.
Now... what is the next issue you have...
geposted Sat 03 Nov 07 @ 4:55 pm
Think your the one we the issues pal!!
geposted Sat 03 Nov 07 @ 6:34 pm
Maybe this thread should be closed before it gets too far out of hand.
geposted Sat 03 Nov 07 @ 8:11 pm
