Forum: Old versions
Topic: Problems with ESI u46 SE audio device
Hi there,
I work with mac, I have two denon cddjs, and I try to use virtualdj with them, but when I select "timecodes" both "single" or "two" in the input section, and "external mixer" in the output section, a "driver error" appears, which is really extrange, cos the driver are perfectly installed (as the U46SE uses Mac OSX own Default Core Audio Driver on an Apple Mac system with Mac OSX 10.3 and higher). With the same configuration and under windows, it works propperly, but I can't find the reason why I cannot make it work... Please any idea?
Saludos!
geposted Thu 08 Nov 07 @ 4:59 pm
sbangsPRO InfinityMember since 2004
hi there
please add your serial there is no mac demo
then you will be able to get the latest pro edition 4.3
or the latest beta 5 beta 2
which allows timecodes to be used with this device
geposted Thu 08 Nov 07 @ 6:27 pm
