I pluged ext HD into macbook n it was fine i then ejected the drive & disconected it - now when i reconect it it dose not show on mac anywere although the lights are on - on
the ext HD further to this i tryed the ext HD on my PC and it worked. I'm baffled...
geposted Thu 08 Nov 07 @ 6:36 pm
what format is it ?
geposted Thu 08 Nov 07 @ 6:49 pm
Hi, what format is what?
geposted Thu 08 Nov 07 @ 6:59 pm
how is the hardrive formatted?
ie fat , ntfs , hfs , extended hfs?
geposted Thu 08 Nov 07 @ 7:28 pm
Sorry, I have no idea. Please can you send instrux's as to how to check..
geposted Thu 08 Nov 07 @ 8:09 pm
on your Pc right click on my computer Manage
and browse down to Disk Manager ,
and look for your external drive it will show u what it is formated as
are other usb devices working ok with your mac?
geposted Thu 08 Nov 07 @ 8:25 pm
Thanks but i don't know how to bring up computer manager
geposted Thu 08 Nov 07 @ 8:40 pm
it dose say fat32 however
geposted Thu 08 Nov 07 @ 8:41 pm
i suggest you copy the files off then
reformat your drive to fat 32 again and then try
if it still fails go to aplications > ultilties > disk utilities
and verify your permissions and try converting the image to a compatible format it recommends
you will see a convert button at the top
geposted Thu 08 Nov 07 @ 8:45 pm
Are ok, thanks for your help! hey while your on any chance of doing me a 17" skin to try out on my macbook as i've not seen one on it yet. i'll pm you my email address..
geposted Thu 08 Nov 07 @ 8:51 pm
