Hello,
need some help, if i play video avi files, everything is fine. If i put the video in the sidelist and put the autoplay on.
Everytime the new video get faded in, after five seconds the sound stucks for a second.
The video files are on a intern drive sata.
My Pc config:
windows XP
AMD Athlon X2 5800+
3072 Ram
Controller: Numark DMC 2
Grafikkarte: HD 2900XT 1024 MB-DDR4
Soundkarte: M-Audio Delta 1010 LT
My Pc config:
windows XP
AMD Athlon X2 5800+
3072 Ram
geposted Thu 08 Nov 07 @ 9:10 pm
I have the same problem here, I tried several configs bt couldnt correct the problem.
nvidia 8600gt 512mb (TC 1gb)
geposted Fri 09 Nov 07 @ 2:05 am
What are the video types ?
If they are using a codec decoder what is the codec ? DivX, 3ivX, etc ?
geposted Fri 09 Nov 07 @ 2:08 am
i use most .avi and few .mpg different codecs. I use vdj decorer as usual. This bug didnt happen to me with vdj4 automix and a lower video card. Maybe it can be caused because of new one deck automiix issue?
By the way, i've read a lot of comments about this new 1deck automix. From my view, i think is really innovative as it lets u the other deck free, so congratulations to the team for every innovation they give. If this video problem can be fixed it would be great.
geposted Fri 09 Nov 07 @ 3:36 am
video's are mpg 4
geposted Fri 09 Nov 07 @ 6:20 am
I was having a similar problem and I was able to trace it to the newest version of Divx (6.7). I unistalled it and use the 3ivx or Xvid codec to decode the videos and it works fine.
Chris
Chris
geposted Mon 12 Nov 07 @ 2:09 am
