Where do I put the samples that I get from this site's download section? Which folder do they go in I mean? Also, since they are not in .mp3 format... how do I go about creating samples myself in that format? Thanks.
Killabee44
Killabee44
geposted Tue 09 Nov 04 @ 11:25 am
The samples must bo copied in your Virtualdj directory \samples
There's often:
C:\Program Files\Virtualdj\samples
You can create .vdj files only with the VDJ sampler.
Create for example a 4 beats loop while playing or while the track is paused and simply click on a sampler loop button. Your sampler is created as a loop. After you'll have to save it (the small circle on the sample corner (for each one). You can also create jingle by clicking twice the jingle button between to points in the track loaded. Your samples are also saved in the \samples directory.
Clax
There's often:
Clax
geposted Tue 09 Nov 04 @ 12:00 pm
K, Thanks Clax. That helps a lot.
Killabee44
Killabee44
geposted Tue 09 Nov 04 @ 9:13 pm
