Forum: VirtualDJ Plugins
Topic: Fruity loops/Abelton?
davey73PRO InfinityMember since 2007
Is there a way to incoperate Fruity loops or Ableton live with virtual DJ? I saw that Fruity loops does not work as a VST plugin But, has anyone actually been able to use thes programs alongside with VDJ?
geposted Mon 12 Nov 07 @ 11:02 pm
spinnaJPRO InfinityMember since 2004
U mean do the looping thingy n ur own tunes??.. Yes u can but u need to have at least 2 com running n both connected to ur mixer so example if one channel from vdj bpm is 130 etc, the same should be apply at fruity loops.. plus minus.. n u have to fine pitch/set it by ear:) I dun think it can be sync automatically both the different software.
geposted Tue 13 Nov 07 @ 7:42 am
sbangsPRO InfinityMember since 2004
virtual dj unfortunately doesnt support rewire so they cant be automaticaly synced to run them on the same pc would require alot of resources
geposted Thu 15 Nov 07 @ 1:22 am
