Hi
Just trying to install my dj conolse mk1 onto Vista Biz Edition 64bit, the drivers seemed to install properly at first as it asked me to plug in the djconsole however this message was left for about a minute then it skipped it (i was trying to find the correct cable). Since then everytime i try to install it it installs but fails to ask for the console to be plugged in. When i try to load up the djconsole.exe an error comes up saying unable to locate HDJAPI.dll file.
Anyone know of a fix, i really need this working.
Thanks
Thanks
geposted Tue 13 Nov 07 @ 12:57 pm
sadly the mk2 or mk1 are not supported on 64 bit operating systems :(
hercules only provides 32 bit drivers
geposted Tue 13 Nov 07 @ 6:40 pm
so i can no longer use my console at all, thats real bad, just upgraded and was waiting to use vdj with the console so it works perfectly (after using it on an OK laptop).
geposted Tue 13 Nov 07 @ 8:05 pm
Thanks for the info skyfx
I need help connecting my Hercules RMX to my window 7 pc and choosing all of the proper drives, etc. I have a dj gig tonight which I may have to cancel. can anyone help me?
geposted Sat 03 Apr 10 @ 11:12 am
You will need to download and install the latest firmware and drivers for the console. You can find links to download on the following page:
http://www.virtualdj.com/wiki/Common_Device_Drivers.html
geposted Sat 03 Apr 10 @ 1:01 pm
