What soundcard would you suggest? I want to use my bcd2000 as a midi controller but would like to get a soundcard that that has a headphone for monitoring and also would like to use a microphone. Also, I need a soundcard hich I can use with TCCD's also. Will the new Numark dj i/o work or it doesn't have enought inputs or outputs for Timecodes?
Can I use an external mixer for headphone and mic hook up and still use the bcd2000 as a controller?
thanks,
thanks,
geposted Tue 13 Nov 07 @ 7:02 pm
you should look at the maya 44 usb or u46djmk2
as a card :)
i would ditch the bcd if you want to use an external mixer
as a card :)
geposted Tue 13 Nov 07 @ 7:25 pm
And to use it fully u need to upgrade to pro if ur thinkin to do timecodes as home edition permit only 5 mins n have limitation. And u have discount too if u upgrade as u own the herc dj console:)
geposted Tue 13 Nov 07 @ 8:13 pm
Will the maya44 or u46Mk2 allow me to use a microphone?
I want to make sure the professional edition is what i really want before i make the purchase.
Thanks,
Thanks,
geposted Tue 13 Nov 07 @ 8:48 pm
The u46mk2 should allow that as there is a mic input:) 4 in 6 out
For maya44 usb, i dun think so as u need to use the input/output for timecoding:) 4 in 4out
But it best to have the mic on the external board mixer n u can listen tru headset tru ur dj mixer:)
geposted Tue 13 Nov 07 @ 8:58 pm
