u46 djmk2 and U46 SE seems to be the same thing...only u46 djmk2 cost 100 euros more... ??? So whats the difference? As i can understand U46 SE wont work with TCV?
geposted Wed 14 Nov 07 @ 6:15 pm
I use the U46 SE with TCV, it works fine as it has 4in/4out. However it lacks the preamp of the U46DJ MK2 edition, therefore you either specify within VirtualDJ to use a software preamp or you use an external hardware preamp (personally I'm using the Behringer BEAT800).
geposted Wed 14 Nov 07 @ 6:33 pm
Except that u46se has no preamp another diference is that u46se has vista drivers and u46dj mk2 not.
so if you running vista keep that in your mind.
geposted Thu 15 Nov 07 @ 5:27 pm
