i was using the bcd2000 with virtual dj and a wierd glitch happened in the middle of a song..........the crossfader on the pc doesnt move when i move the bcd crossfader but it does move when i use the vollume fader on the bcd for channel a.........it moves inperfect harmony with t he volume fader......ever since the problem still exists....i reinstalled the drivers......to no avail....i even tried it with a different software"djdecks" and with "bdj".......any ideas on how to fix?
geposted Mon 19 Nov 07 @ 10:56 pm
I guess you need to link crossfaders in video options.
geposted Tue 20 Nov 07 @ 6:58 pm
I had problems with mine when I 1st got it. Sound woudl drop out, it would stop responding. Disabled ACPI battery in the device manager, worked fine. Set it on the shelf for a while. Tried it again same problem. Either it worked with VDJ 4.x or some sort of windows update that is causing the issue. I am now running VDJ 5.6
geposted Fri 28 Dec 07 @ 1:03 am
You could get rid of that piece of junk altogether and have no more problems. That is a
sure fix!
BC
sure fix!
BC
geposted Sat 29 Dec 07 @ 8:28 am
