Hey,
so, if i've got a USB Mixer (e.g Numark DXM01USB), two simple turntables and two timecoded vinyls, could i use it with VirtualDJ, with a normal sound card ? Could i simply mix and scratch with them, like normal vinyls ?
-ANTer
-ANTer
geposted Mon 19 Nov 07 @ 11:13 pm
that would not be a good mixer for tcv
use i would , get a maya 44 usb soundcard
and then get a standard mixer if you are on a tight budget
if you have a larger budget check out the maya and the nuo4
http://www.virtualdj.com/products/hardware.html
geposted Tue 20 Nov 07 @ 1:56 pm
Yes you can. If you already have that mixer it will work as long as you get a soundcard like the one Sky mentioned.
geposted Tue 20 Nov 07 @ 5:31 pm
so what you are saying is that yes i can use TCV if i use the maya44 usb soundcard? thanks for your time.
geposted Wed 28 Nov 07 @ 1:49 am
