VDJ mostly works fine, but twice recently I've lost a channel whilst playing out! I'm using a Maya44 with the latest 2.53 drivers + time-coded vinyl, though it has happened without the TC Vinyl too. (ie. in TC ASIO mode and Advanced ASIO)
I think it was channel 3+4 that dropped, the other one continued to work ok, but as you can guess this limited my mixing possibilities!
I wasn't doing anything special when it happened, VDJ *looked* OK, and I remember it still responded visually to the TC Vinyl, just no audio was coming out of that channel.
Anything I can do about this? Have other users had similar trouble?
Cheers b
Cheers b
geposted Thu 11 Nov 04 @ 1:31 pm
MAYA 44 works fine with VDJ in asio mode ...2 line out and 2 line in
Switch to ASIO mode within VirtualDJ after have installed the driver
Don't forget to mute the monitor outputs if you're using the timecoded vinyls using the ASIO config pannel
geposted Thu 11 Nov 04 @ 2:04 pm
As I said, it works fine, all 4 channels play, but on occasion one channel drops out, requiring a reboot, which is not much good in the middle of a set...
geposted Fri 12 Nov 04 @ 9:41 pm
I don't have a maya 44 but i have a simialr problem with one side dropping after about 3 hours of mixing.
geposted Fri 12 Nov 04 @ 9:48 pm
Spoke to tech support and they suggested it's a dodgy lead ... but I'm thinking this is unlikely geiven it's a brand new s/card with a built in lead?
geposted Sat 13 Nov 04 @ 12:33 am
by lead i think they mean the cable coming out of your sound card I could be wrong, However my problem is not lead its software related.
geposted Sat 13 Nov 04 @ 12:49 am
Yeah that's right... can't replace the damn lead though without replacing the whole s/card
geposted Sat 13 Nov 04 @ 12:56 am
jomtones, i have maya44usb too, and i noticed some
"refresh" problems on the maya mixer/panel.
When i use other or switch between asio programs.
If you have this problem again, just open the mixer/panel
and move and/or mute/unmute the sliders with the problem,
and see if the sound comes back.
Let me know.
Let me know.
geposted Sat 13 Nov 04 @ 3:41 am
Thanks, I'll give that a go next time ... hopefully not in the middle of a set!
geposted Sat 13 Nov 04 @ 1:47 pm
