I have disconnected my controller for 3 weeks and now when I start vitual dj it does not recognize the controller. The drivers are installed and midi works also. In the setup where it says Beringer2000 when pressed the light is red and not greeen. How can I fix this ?
geposted Thu 22 Nov 07 @ 7:50 pm
what version do you use?
if you havent used it for 3 weeks as a demo user is likely your trial has expired and you need to purchase this software if you like it
i hope to see you with us as a pro user soon
geposted Thu 22 Nov 07 @ 9:54 pm
Wow, you are smart...! How do I get it to work again.
geposted Thu 22 Nov 07 @ 10:34 pm
http://www.virtualdj.com/purchase/
purchase your self a copy of Virtual DJ pro
and you will get unlimited acess to virtual dj , free updates , skins and plugins
geposted Thu 22 Nov 07 @ 11:17 pm
the demo is still active and why would I buy it sice this bcd2000 stoped working. what does this say about this virtual dj product. Unless I fix this issue then I will never buy VDJ.
geposted Fri 23 Nov 07 @ 6:01 pm
If u buy VDJ, that problem could be solved unless there is a problems with ur BCD unit itself. Pro user also can have custom mappers on bcd2000 n bcd3000.
And lastly are u sure that ur BCD not werkin with or without VDJ?
geposted Fri 23 Nov 07 @ 6:30 pm
and it never will work sucessfuly unless you use an offical stable release
as unoffical versions contain damaged code ,
You should aslo try checking for any hardware conflicts the bcd can have problems with instability if it clashes with a piece of existing hardware on your machine
such as your video , wireless or soundcard
http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
i hope you will join us soon as a pro user :)
geposted Fri 23 Nov 07 @ 10:33 pm
