hi, how is this card for cue/vdj? one of the mates is thinkin about gettin cue and gettin the u46se to use for it. he's playing timecode useage.
http://www.thomann.de/gb/esi_u46_se.htm
i have a u46dj but i don't think you can get them anymore.
cheers
cheers
geposted Thu 22 Nov 07 @ 11:15 pm
it is good it is on the recommended hardware page on this site
http://www.virtualdj.com/products/hardware.html
geposted Thu 22 Nov 07 @ 11:18 pm
cheers
i can see the u46dj , but its the u46se one i askin about.
geposted Fri 23 Nov 07 @ 12:18 am
djfs wrote :
cheers
It werk the same as u46dj card but minus the preamp..If u compare both model specs, it is the same..
U46djmk2 is the new version.
If i not wrong some user on this forum did use that u46se card;)
http://www.virtualdj.com/forums/80511/Hardware_Technical_Support/u46_djmk2_and_U46_SE_soundcard_.html
geposted Fri 23 Nov 07 @ 3:25 am
cool cheers. i noticed that it didn't have the preamp.
looks like it should be ok then.
we should have another membe on board soon :D
geposted Fri 23 Nov 07 @ 1:16 pm
something important:
the "SE" has vista drivers (u46dj has not)
geposted Fri 23 Nov 07 @ 8:35 pm
yes, of course, the "SE" has vista drivers, but they don't work!!!
I have just bought a u46SE from thomann.de but vista doesn't find my device :(
I try, and try, and try again, but very very and very unsuccessfully. :D
so, maybe I can try asio4all.
can you help me?
thanks
bye
can you help me?
thanks
bye
geposted Thu 06 Dec 07 @ 1:52 pm
can you help me?
can you help me?
This is sad, did you tried this driver from this site ?
http://download.esi-audio.com/?w=esi&p=42&g=2&l=en
I don't have the card nor use vista !... so i can't help, anyone else can confirm this ?
ok, i'll try to help ...
-Deactivate "User acount control" (UAC) for your account, (control panel ->user acounts->etc) (needs restart)
-If driver has an installation .exe file (setup) try to run it as "addministrator"
(right click on the file "run it as addministrator")
If not a setup file but a folder, try "update driver" from device manager and locate the folder...
Let us know if this helps...
geposted Sat 08 Dec 07 @ 10:29 am
hello
i also have the u46se....when you want to work with card on vista you will have many problems, because you have to wait until the 2 service of vista comes...However, with Asio4all the u46se plays constant ánd you even can use it.... next problem is that the card only has line inputs and no phono inputs so you only can play timecode cds and no vinlys...so all in all i bought now the m-audio conectiv and this soundcard is perfect(sorry my english is very bad)
geposted Sat 08 Dec 07 @ 10:52 am
you can play vinyls in the line input with vdj as the software changes the levels for ya.
geposted Sat 08 Dec 07 @ 11:30 am
hi,
I've downloaded vista drivers from download.esi-audio.com and they don't work in vista!
so, I'll try proceedings you have just write for me and then I will post results and let you now if you're right :D
thanks,
matteo
p.s. I tried asio4all, but vista doesn't find my audio device too
bye
geposted Sun 09 Dec 07 @ 4:01 am
which asio4all driver did you take?
@djfs
i think that this don`t work with the line inputs, because vdj don`t even see the timecode cds...you only hear the signal of the timecode cds,but you can not use them.
@djfs
geposted Sun 09 Dec 07 @ 4:15 am
I try asio4all 2.7, asio4all 2.8 beta1 and asio4all 2.8beta2. vista take them right, but then it doesn't find my device.
and you? which asio4all do you use?
geposted Sun 09 Dec 07 @ 10:13 am
I use the ASIO4ALL_2_8_Beta_2_English
geposted Sun 09 Dec 07 @ 10:32 am
so, I have tried to install u46 again but nothing!!
thanks apopsis for your help, but vista is the question!!
what can I do now??
@djfella,
how do you install your asio4all?can you tell me your proceedings??
thanks
what can I do now??
@djfella,
thanks
geposted Sun 09 Dec 07 @ 11:07 am
i instal asio4all normal(no special installation)... but i also install u46se and so there were no problems,they worked together in harmony" :-)
i don`t know what proceedings meen....can you please translate me??
geposted Mon 10 Dec 07 @ 1:09 pm
sorry for my very bad english,
so, I want to know how you install asio4all!
if you can,
thank you
if you can,
thank you
geposted Tue 11 Dec 07 @ 8:41 am
my english is also very bad :-) so don`t worry.i install asio4all normal...did you try to switch off your firewall and than install ones more. ...maybe it helps
geposted Tue 11 Dec 07 @ 11:34 am
ok, thank you so much dj fella!
I'll try with disabled firewall ;)
bye
bye
geposted Wed 12 Dec 07 @ 7:23 am
and?does the soundkart work now correct??
geposted Wed 12 Dec 07 @ 11:43 am
