Hi
I bought a macbook and installed vdj 5 beta 3 version via the download center, i am licensed so that s fine
that went ok, but the mac isn t recognizing my interface nl hercules dj console mk2
i tried changing settings in audio but still nothing
maybe i should run it in windows, but i want all on my mac. possible?
cheers
cheers
geposted Fri 23 Nov 07 @ 5:47 pm
Yes it is possible,,.... U need to dl the mac drivers;)
geposted Fri 23 Nov 07 @ 6:09 pm
if you are using the latest driver on the site ,
Before trying to install them, make sure to:
1) display the installation package .pkg file (right click the file with Ctrl-click) and select ShowPackage Contents
2) Enter in Contents/Resource and delete the file InstallationCheck
3) Run the installation package again, and this time the installation will run normally.
The drivers to be used are the following:
ftp://ftp.hercules.com/pub/webupdate/DJMP3/HDJMP3_Tiger_3_2.pkg.zip
geposted Fri 23 Nov 07 @ 9:46 pm
Where can i find the driver you tell ?
Where can I find the installation package ?
When I open the link it says cannot install on this computer ..
strange
strange
geposted Sat 24 Nov 07 @ 1:45 pm
howdy as of today a new 10.5 driver for mk2 is released if your using leopard this should solve this for you :
http://www.virtualdj.com/forums/81056/MAC_Version_Technical_Support/New_driver_for_Hercules_DJ_Control_MP3_and_DJconsole_MK2_(Leopard_Compatible).html
geposted Sat 24 Nov 07 @ 2:39 pm
