Topic: VirtualDJ v5.0 rev6 - Page: 1
Elle est arrivée ! Tous à vos centres de téléchargement !!!
geposted Sun 02 Dec 07 @ 6:24 pm
il y a une liste des changement«???merci
sur le forom generale
Hello,
Again, while we are still working on 5.1 (which will be ready soon by the way), we will still release bug fixes on a regular basis as long as we still find bugs (which is getting harder and harder :D).
So here is revision 6, that corrects some bugs and some rare crashes from revision 5.
You can find it in your download center.
Here is the complete change log:
new features
- added support for MP4 video files
- can load and play ambiant video files with no audio
- compatible with ID3 v2.4 tags
- new browser columns "filesize", "filedate"
- optimized for big iTunes library
- new actions "auto_mix_next" and "auto_mix_next_sidelist"
- new pitch ranges 6,8,10,12,15,20,25,33,50% or anything else via registry PitchRange
bug fixes
- freeze in sort thread fixed
- fixed crash when sync_no_cbg before begining of song
- fixed crash automix on some DRM-protected files
- fixed can crash when automixing video sometimes
- improved detect video/karaoke on "add to searchdb" recurse
- fixed preview crash on DRM-protected files
- fixed search in title/artist when filepath/filename not selected
- fixed crash with ID3 unicode comment
- DAC3 fixed
- Denon HC4500 fixed
- "+" in browser for history doesn't show if history is empty
- "move up", "move down" folder context menu doesn't show if topmost/bottommost
- fixed plugins loaded on startup don't show interface
- don't add folder "$Recycle.Bin" to search database
- bug with empty codec list saved as garbage fixed
- bug with thread freeze while closing causing empty codec list fixed
- fixed load mac database on pc and pc on mac.
- fix wrong comments from ID3 tags written by iTunes
- import cover from iTunes tags (.m4a files)
- fix album name from iTunes tags (.m4a files)
- fixed right deck plugin dropdown acting on left deck
Cool :-)
J'aurai peut être plus les plantages que j'ai eu durant ma dernière soirée :-D
Encore rien pour mes CBG's qui valse...
Est-il conseillé de désinstaller la rev.5 avant de mettre la v.6?
Salut,
Je n'ai pas desinstaller la rev5 avant d'installer la rev6,tout marche nickel.
Thanks mister dj59!
Happy
hummm ou est la VirtualDJ v5.0 rev6 car moi je l'ai pas dans le centre de téléchargement?
comment vous faite pour l'avoir avant nous?
bref c'était pareil avec la version VirtualDJ v5.0 rev5
beaucoup de gent disait quel etait dispo mais moi je l'ai eu 7 jours apres
bisard cette histoire il doit y avoir des favorisés je pensse
sur ce vivement que je puisse le DL ciao
iibel bonjour,
Regardes bien parmi tes différents fichiers à téléchargés
Pour ma part j'ai trouvé cette version "entre" les versions Mac
Bons Mix's
rudj
le deuxième rang
merci beaucoup pour cette update,mais c»'est triste de ne pas retouver les codec pour les fichiers »KOK-KFN-KAR....ont espere toujour....merci
enfin
enfin
enfin...j en ai revé le pitch à + ou - 50% enfin......c pas trop tot
Re tous
bon bien toujour pas cette nouvelle version moi j'ai ca
>> Numark VirtualVinyl v5.0 rev5 PC (full install) (15 MB) - Téléchargé 2 fois -
>> Numark VirtualVinyl v5.0 BETA Mac (full install) (15 MB) - Téléchargé 0 fois -
>> Numark VirtualVinyl v5.0 BETA 2 Mac (full install) (15 MB) - Téléchargé 0 fois -
>> Numark VirtualVinyl v5.0 BETA 3 Mac (full install) (16 MB) - Téléchargé 0 fois -
>> Numark VirtualVinyl v4.3 Mac (full install) (18 MB) - Téléchargé 0 fois -
je vous le dit vous devez etre VIP moi j'ai toujour les nouvelle version genre une semaine plus tard
bon allé je restre positif je croise les doigt pitetre ce soir ca sera bon je vous tien au courant ciao
Bonjour libel
avez vous été voir sur le site NUmark vu que vous avez Virtual Vinyl ?
Dj Al
chez numark il y a rien
bon toujour rien dans mon centre de telechargement
Dj Redman the Madboss wrote :
enfin
enfin
Et moi du +/-100% quelle joie!!!
Les gars le pitch à +ou- 50 ou 100% les morceaux ne ressemblent plus a rien.
moi je l'utilise à max 20%
Mais bon je suis de le vieille ecole
enfin
enfin
Et pourquoi ne pas commencer par dire "merci" tout simplement? Je vous signale que vous n'avez pas déboursé un rond por ces améiorations.
Mais ce n'est que mon avis...
enfin
enfin
lol !!
MEEEERRCCIIIIII !!!!!!
77%
