is there anyway that i could use the hercules soundcard,so i could use the timecodes cd.i just bought two denon s3500
thanks in advance
thanks in advance
geposted Mon 03 Dec 07 @ 1:13 pm
yes , you should follow the mk2 setup guide which can be found in the hardware stickies
but choose cd instead of vinyl
you can get the timecoded cds here
http://www.virtualdj.com/products/timecode/cd.html
geposted Sat 22 Dec 07 @ 6:23 pm
f dip i would also recommend getting the asio4all driver to set up your denons,
so make sure to google "asio4all" then when you find the page download the beta 2.8
once you do that, open the settings up, disable the internal soundcard, then enable the herc, and start from the top latency buffer and slowly lower the fader setting until you reach the settings that allows you to play and mix without hearing any pops or clicks or jittery watery sounds,
let me know how it goes for you,
JC
JC
geposted Tue 25 Dec 07 @ 12:09 am
try and setup with the mk2 drivers first
and then if that performs slowly or
if that doesnt work then try asio for all as this is a hack and may not work
if you want to use the asio 4 all follow the steps here ,
http://www.virtualdj.com/forums/68291/Hardware_Technical_Support/Some_general_info_about_Hercules_DJ_Console_MK2
geposted Tue 25 Dec 07 @ 6:00 am
