hello fellow virtual djer's
ok this is where i'm stuck at right now......i have 2 denon s3500's using the hercules mk2...right now i only have 1 denon working as a timecoded,but i can't get the second denon to have any music coming threw,,,
geposted Mon 03 Dec 07 @ 10:28 pm
Hi F_Dip
Look here for how to set up tccd using herc mk2 as soundcard
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__).html?page=1
geposted Mon 03 Dec 07 @ 11:10 pm
HELLO SPINNAJ
I HAVE TRIED TO DO THE CONNECTIONS AS U SAID....BUT I KEEP GETTING IS "ERROR IN ASIO SOUNDCARD"
geposted Thu 06 Dec 07 @ 12:45 pm
hi as u are using mk2 as soundcard, do remember to activate asio from herc control panel everytime b4 u opened vdj as mk2 always restart to wdm modes upon closing;)
geposted Thu 06 Dec 07 @ 1:06 pm
HI THANKS FOR YOUR HELP....
YES I'M USING THE MK2 AS THE SOUNDCARD....NOW IF U CAN GO THREW THE STEPS WITH ME VERY SLOWLY CAUSE
I'M A FIRST TIME USER....
ALSO WHAT IS "WDM"
SORRY FOR BEING ILLITERATE
ALSO WHAT IS "WDM"
geposted Thu 06 Dec 07 @ 1:24 pm
Just b4 u opened vdj itself, go to herc control panel n select asio..it will fixed the problem as i supposed u already have set the config in vdj in timescodes mode. WDM is window driver model;)
geposted Thu 06 Dec 07 @ 2:34 pm
ok i got it.....now i have all sounds coming out of 1 channel.....and the crossfade doesn't work
geposted Thu 06 Dec 07 @ 2:42 pm
Hi f_dip, sorry for the late respone, just back from overseas..
What is ur setting in sound config of vdj
Try this:
Input: Timescodes
Output: external mixer
SC: asio / mk2
Asio driver : Mk2 asio
Input channel: Channel 1/2 right deck / Channel 3/4 left deck
Try this:
Input: Timescodes
SC: asio / mk2
geposted Wed 12 Dec 07 @ 10:34 pm
