Hello, i'm very exited to buy VDJ, but i have some questions.
The sound card Focusrite Saffire Pro FIREWIRE works with VDJ - Tomecode on vinyl? Or only the Saffire LE works?
The sound card ESI Quata Fire 610 Works with Timecode too?
What is the best firewire sound card to work with VDJ?
Thanks!!!
Edancer.
Thanks!!!
Edancer.
geposted Wed 05 Dec 07 @ 7:26 pm
Any sound card with ASIO that has sufficient input and outputs for your needs will be suitable for timecode vinyl use.
Typically this means having a minimum of 4 inputs and 4 outputs (ie 2 stereo of each), although you can have single TCV mode that will only require one input.
From what I can see the Focusrite Saffire Pro has 26 inputs and 26 outputs with ASIO drivers, so I think that will be enough ;) The ESI Quata Fire 610 has 6 inputs and 10 outputs, also with ASIO drivers - so again more than enough.
Hope this helps, but I can't comment on the performance or stability of either since I haven't used them...
Regards,
Scott
Regards,
Scott
geposted Wed 05 Dec 07 @ 10:56 pm
Hello every body!!!!!
I finish buy a Focusrite Saffire LE, very nice interface. But now, i really like to know how i can use the Timecode with this interfaçe. How cables i need to turn on for this machine works? I search here a lot tutorials, but no one explain nothing about this interface.
Thanks a lot
Thanks a lot
geposted Fri 21 Dec 07 @ 6:54 am
Up, please!
geposted Fri 04 Jan 08 @ 4:20 pm
This Guide might help you set it up.
http://www.virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
Simply put, if your soundcard has 4 inputs and 4 outputs which is stated above, TT's right and left into the 4 inputs on your soundcard, 4 output of soundcard go to left/right channel of your mixer. Then you'll need to follow the guide to setup the software for timecode.
geposted Sun 06 Jan 08 @ 8:44 am
go with final scratch open by stanton
geposted Sun 06 Jan 08 @ 2:59 pm
