If it came with Numark CueLE and it has not already been registered, then you can use that.
Otherwise you will need to purchase VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
geposted Fri 17 Dec 10 @ 2:26 pm
Can't seem to get full screen video. Only see mixer video. Everything else works
geposted Fri 24 Jun 11 @ 10:12 am
Sorry, full screen video is only possible in the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html
All other versions including Home FREE are limited to a small video output window only.
geposted Fri 24 Jun 11 @ 12:59 pm
hi, is anyone else having problems with the hurcules 4Mx, half way through the night the jog wheel stops working as it should and starts controling the playlist area, so then i cant use it to line up the beats unless i restart the computer. Any Ideas ?? thanks
geposted Thu 28 Jul 11 @ 1:18 pm
By default, the jogwheel will browse songs when you hold down the headphone pre-listen buttons or the up/down button.
It may be that this has not released for some reason, or maybe you have customised the mapping so that these do not function correctly any more.
To disengage the browsing, either press and release one of the above buttons or map a button or keyboard shortcut of your choice to the following:
deck left wheel_mode "jog" & deck right wheel_mode "jog"
For basic mapping instructions, please see http://www.virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
geposted Fri 29 Jul 11 @ 6:32 am
i can't use my numark total control with the virtual pro 8
geposted Thu 15 May 14 @ 12:55 pm
If you are having issues in version 8 please post them herer: http://www.virtualdj.com/forums/75/VirtualDJ_8_Pre-Release_Forum.html
[CLOSED]
geposted Thu 15 May 14 @ 1:27 pm
