vdj is not acting right when useing the pitch button vdg will do nothing when u move the pctch up or down i think it's a Bug IN V 5.rev6.
geposted Wed 12 Dec 07 @ 11:11 pm
Are you using Moramax BCD 3000 Mapper? if yes and your mapper version is 3.2 or earlier, this problem is known by Moramax and is fixed on
3.3 Mapper here: Moramax 3.3 Mapper
The problem has been discoverd and documented on 3.2 BCD 2000 Mapper here: http://www.virtualdj.com/forums/81661/Hardware_Technical_Support/BCD_2000_Mapper_problem_with_vdj_5_Rev_6_Pitch_Fader.html
I think same problem occur for BCD 3000 as VDJ 5 Rev 6 introduced new ranges in tempo pitch.
If you're not using the mapper, I recommend you to use it. And this problem will probably be fixed.
geposted Fri 14 Dec 07 @ 8:29 am
