To any that have the CM200USB mixer,
My Mic input on my Vestax Mixer took a dump tonight. So I'm going to send it off for warranty. I need another mixer in the meantime and was thinking of Getting this model.
Can this mixer work in 3 channel mode?
I mean can I assign the deck outputs to the USB soundcards and still use my regular soundcard to place samples in a third channel?
I have a three channel mixer that is nicely set up like this but only use one soundcard (5.1)
This mixer has two soundcard built in and I would need a third to have samples going to a seperate channel.
Seems like overkill to me.
geposted Sun 16 Dec 07 @ 5:33 am
Hi Marcel,
No, you can not use a third channel in the mixer for samples, since it has two usb cables (one for each sound card) and vdj has not an option for selecting three sound cards, which is the ammount of cards you'd be using when using samples.
I'm looking forward to have the possibility in the next versions of vdj, since I also would like to use a third chanel for samples only.
geposted Sun 16 Dec 07 @ 3:50 pm
Crap.
geposted Sun 16 Dec 07 @ 4:12 pm
