Before buy Virtual Dj I want to check out the program!
Is it possible to run it with 2 Soundblaster Soundcards ?
geposted Sun 16 Dec 07 @ 3:11 pm
For regular audio output the Full Pro version supports sending the two decks to a mixer using only a single soundblaster 5.1 card.
If you are going to use 2 cards you should use 2 Different branded soundcards. Using the exact same card causes conflicts.
geposted Sun 16 Dec 07 @ 3:41 pm
Make sure that the two cards are somewhat the same in terms of their output and performance though
<a href="http://www.precisedjs.com"> San Diego Wedding DJ </a>
<a href="http://www.precisedjs.com"> San Diego Video DJ </a>
geposted Mon 17 Dec 07 @ 12:31 pm
