Hi,
i downloaded samples , i have loaded them into my sampler but when i try to play them i hear no sound even though they seem to be playing in the sampler .
I have the sampler volume turned up , also none of the samples that come with Vdj work either .
I use a Gigaport going to an external mixer running Asio mode.
geposted Tue 18 Dec 07 @ 5:41 am
Anybody please ?
geposted Thu 20 Dec 07 @ 11:32 am
I guess no one knows the answer to this , then ?
geposted Sat 22 Dec 07 @ 4:36 am
do they work with your internal card
if not go to options > codecs and add .VDJ and vdj
and choose the internal vdj sample decoder
geposted Sat 22 Dec 07 @ 5:17 am
Hi,
yes i chose the internal soundcard in the sound set up and yes the samples play fine.
I don't quite understand when you say choose the internal vdj sample decoder, how do i do that ?
Thanks for your help.
geposted Sun 23 Dec 07 @ 6:59 am
