Forum: Old versions
Topic: v5 Problems - please HELP
I upgraded from v 4 to v5 rev 6.
This is a 2.4Ghz PC (Core 2 Duo) with 2GB of memory. No other apps running.
While a song is playing, the record seems to "hickup" while it's turning. Some songs that played fine on v4 load up and play an extremely loud static / white noise sound.
I've got a gig tonight and would like to use v5. Otherwise, I'll have to roll back to 4.
Please resond AND email tommye (at) specialtysound.com (I will get those on my cell phone) so I can remedy this before my show starts tonight.
THANKS!!!
geposted Wed 19 Dec 07 @ 2:38 pm
sbangsPRO InfinityMember since 2004
what soundcard do you use?
try to set autolatency in options
options > performances
untick safe and overclock ,
geposted Sat 22 Dec 07 @ 6:05 pm
