Forum: Old versions
Topic: icdx platter pops up video screen
grugPRO InfinityMember since 2004
I'm using VDJ 5.0 rev 6 and I get the problem with the video window popping up when i touch one of the icdx platters occasionally. It will also reset the pitch of the track loaded and occasionally reset my hercules mk1 console. It is happening at least once or twice in a 3 hour set most of the times I get around it by making sure the next song is looped in early enough but sometimes it can be abit frantic changing the settings back. This happens to mp3 files only.
I tried to post in the forum further down where this was a known issue but the forum was closed and that was about 6 months ago. Is this issue still be worked on or was it thought to be fixed?
Cheers
grug
geposted Wed 19 Dec 07 @ 4:56 pm
Cheers
grug
Nevermind, got the answer that it's still being worked on.
geposted Thu 20 Dec 07 @ 4:33 pm
cstollPRO InfinityMember since 2004
Are you using only audio files ? No Video. No Karaoke. ? Then disable the Video features. Go to the Config->Video tab and DISABLE video using the button at the top of that panel.
geposted Sat 22 Dec 07 @ 12:05 pm
