Forum: Old versions
Topic: Pitch problems
Hello
I have VDJ DJC Edition.
When i speed the song up, i want the song to go into a higher pitch (so it sounds squeaky, if you will)
I dont know if im missing a option or something but i cant find anthing.
Cheers
Tom Bullock
geposted Fri 21 Dec 07 @ 6:02 am
sbangsPRO InfinityMember since 2004
there is a key-changer plugin in vdj pro , also in the latest 5r6 pro it is possible to choose your desired pitch ranges in the options
so you can choose a much larger change
check out the demo see if it meets your needs :)
geposted Sat 22 Dec 07 @ 6:01 pm
