Bugs ?
1 - I create a folder for example December 2007. I put some files in it. I start vdj. In the browser i search this folder, and click right-mouse button and select "add folder to search db". Then another day i put some new files in this folder. I start vdj, and the new files are not in the db. I have to make another "add folder to search db". Is this correct ? I suppose that once you have added one folder to the db, when you check, fix and clean this db it should update the db removing not existing files, and adding new ones .... Perhaps a bug ?
2 - In rev6 it only recognizes audio files. vdj cant find any video file ( mpg, mpeg, vob ...). Seems like only can find audio files ( mp3, wma ...). Cant find option to search video files and karaoke files. Perhaps a bug ? Something missing in rev6 ?
Thanks in advance
Thanks in advance
geposted Fri 21 Dec 07 @ 6:25 am
