When I plug my USB Splitter into my macbook pro, Cue will not play on either side. Any help?
geposted Sun 23 Dec 07 @ 9:49 am
what sound options do you choose
that will have terribly high latency
geposted Sun 23 Dec 07 @ 1:02 pm
DJ IO split to run on my mixer.
My set up is as follows"
Macbook Pro
Total Control
DJ Io
I am trying to connect a mouse.
Macbook Pro
Total Control
DJ Io
geposted Sun 23 Dec 07 @ 6:27 pm
you should set
inputs : none
output : headphones
card : asio
driver : dj /io
inputs : none
output : headphones
card : asio
driver : dj /io
geposted Sun 23 Dec 07 @ 6:59 pm
I do not have the asio option.
Am I missing something?
geposted Wed 26 Dec 07 @ 9:59 pm
what options are available to you ?
try configuring with a 4.1
inputs : none
outputs : headphones
card : 4.1
driver : dj/1o
inputs : none
card : 4.1
driver : dj/1o
geposted Thu 27 Dec 07 @ 5:18 am
are you using tiger because the djio currently does not work with leopard.
geposted Thu 27 Dec 07 @ 10:05 am
Not using leopard.
I had it working, then went to change a skin, that was it.
Not sure what is going on.
The only thing I can do is dump the program in the trash then reinstall.
But nothing has helped.
geposted Thu 27 Dec 07 @ 3:18 pm
Sky,
That is exactly what I am doing.
geposted Thu 27 Dec 07 @ 3:19 pm
I just trued version 4.3 and the exact same thing happened.
geposted Thu 27 Dec 07 @ 3:23 pm
ASIO doesn't exist in mac, apple functions on Core Audio, totally different.
To make DJ I/O work properly you need to set the card to 4.1
DJ I/O functions on USB 2.0, if you do not have a USB 2.0 hub and USB 2.0 cable, your DJ I/O will not function properly.
Further more having a powered hub adds more stability if not piece of mind.
The best option is to never run your sound card on a hub. If you have to, well then you have to, but avoiding it is better off.
Also on your mac, if 15"pro/powerbook or above, you should use the left port, which is tied directly to motherboard (port on the right is bussed).
If on a macbook, the front most port is the equivalent.
It's hard to use all these devices, I run into it all the time, so a powered USB 2.0 is your best bet.
geposted Thu 27 Dec 07 @ 4:57 pm
Thanks.
I have now figured it out to be a DJ IO issue.
I have downloaded the latest update, I made a difference. Still not the best, but I will try a powered hub.
Thanks for all of your help.
I am really becoming a fan of this software!
geposted Thu 27 Dec 07 @ 10:10 pm
is the card detected by osx?
1. Open finder
2. Select Applications
3. Open Numark USB Audio Panel
4. Confirm Status says "Connected".
1. Open finder
geposted Fri 28 Dec 07 @ 4:59 am
It was a DJ IO problem.
Fixed, all is great!
geposted Sun 13 Jan 08 @ 9:50 pm
could you explain what the problem was? would be nice if other users run into the same problem in the future...
geposted Mon 14 Jan 08 @ 5:59 am
The driver I was using was not updated.
I downloaded the newest driver from the Numark site.
geposted Tue 15 Jan 08 @ 12:47 pm
