Hey,
i brought VDJ last year, and i want to download more plugins, effects and updates.
the only problem i have is that i cant remember my login, so i have had to make this one using another email address because it wont accept the original email address that i used to buy virtual dj,
Can someone give me some help and advise,
thanks
Kris
thanks
Kris
geposted Sun 23 Dec 07 @ 1:07 pm
************************SORRY, THE MESSAGE ABOVE I TYPED WRONG, PLEASE READ THIS ONE, THANKYOU**********************
Hey,
the only problem i have is that i cant remember my login, so i have had to make this one using another email address because i forgot my original login that i used to purchase virtual dk
thanks
Kris
Hey,
thanks
Kris
geposted Sun 23 Dec 07 @ 1:10 pm
robotsuk
can you remember your password? if you can put that in at log in, failing that write a ticket to support staff
Tayla
Tayla
if you need your password , but can remember your serial or email
http://www.virtualdj.com/contact/step2b.html
if you can remember the credit card number and your adress at time of purchase
contact the team
contact the team
geposted Sun 23 Dec 07 @ 1:17 pm
AHHH
thankyou people
i now got it
TY
Kris
thankyou people
i now got it
TY
Kris
geposted Sun 23 Dec 07 @ 1:26 pm
no probs
geposted Sun 23 Dec 07 @ 1:54 pm
djrobots123 was your login name
The system should have sent your password to your registered email account
You should be able to access the download center using the forum password.
If you wish to change email address do so in your member profile area and contact eservice so we can do the same on the license registration, they must match.
r
r
geposted Sun 23 Dec 07 @ 2:33 pm
hi im trying the trial of virtual dj and want to log in
I brought atomix and my login details works fine
how can ii login to virtual dj its not allowing me to do so with the samelogin details what can i do?
geposted Fri 13 Jun 08 @ 2:30 am
what you mean? You are at the Virtual DJ forum now,and your AtomixMP3 forum login details should work fine here too, as far I as I know...
geposted Fri 13 Jun 08 @ 10:04 am
